Hi Guys,
Hoping someone out there can help a DIYer with some ideas as I'd like to rule out any simple things first before calling in an expert.
So I have a Glow worm flexicom 24hx with an intermittent Error F25 error. I read that this indicates low pressure / poor circulation. It is on an old f&e system, I've taken the pump off and visually inspected it (had some build up but not enough to cause issues). I suspected the pump as the downstairs rads don't get very hot unless I switch off the upstairs rads (they have TRV's) - the system might just need rebalancing though.
I did try running some X400 through the system and that seemed to magically clear the fault and all the rads got nice and hot (inc downstairs ones) until about 4 weeks later and the error re-occured this reminded me to drain down the system to remove the x400 and i refilled & topped up with inhibitor.
Low and behold the problem's back I have assumed the issue is to do with sludge/build up in the crappy micro bore system I have, I'm about to try again with cleaning chemicals but wonder if i'm missing something obvious that i've overlooked. Maybe i didn't clean out all the muck as I only drained down from one point?
When I drained down the system it didn't seem dirty at all :-/
Thanks in advance
Al
Thanks in advance
Al
