Both motorised valves are functioning correctly i.e. opening and closing and operating microswitch powering pump and boiler feed. Pump operating normally. Operation of boiler became eratic last week and failed to fire up in the morning on the programmer. Checked overheat reset button beneath boiler control box, had not activated. Then for unknown reason was ok for two or three days but has now packed up completely. Flue fan operates when the boiler stat is turned up and stops when turned back to zero. Checked operation of the two twin contact solenoid switches for operation. When viewed from the top, looking down onto the pcb the left hand solenoid contacts close when boiler turned on via the boiler stat. When the HT lead from the ignighter is earthed via metal surface of boiler the right hand solenoid switch contacts close and open again momentarily when the ht lead is removed from touching a metal component of the boiler. I have checked the operation of the air pressure switch but not measures the operating pressures and this appears to operating satisfactorily. Basically when I fire up the boiler, the motorised valves operate when the cylinder and rooms are calling for heat, the pump operates as does the flue fan, the next thing that normally happens is that the ignighter starts clicking, the gas solenoid valve opens and away it goes. I suspect it may be the ht transformer on the pcb but I don't want to make an expensive mistake. Any clues or comments please?
