Glow-worm fuelsaver 30 B
Hello
I have had some problems with the pilot light going out on my boiler. I have remedied it twice by replacing the thermo-couple but the first replacement lasted two years and second lasted only 4 months and now I am not even sure if the thermocouples were faulty in the first place, because something, I don't know what, happened at the time I was examining the thermo yesterday, and since then the pilot light has been burning much more energetically and the boiler is easier to light.
Before the "happening", the pilot flame did not envelope the end of the thermo couple, the flame was softer and it "floated" upwards, now it"jets" out to the side and covers the thermo end.
I dismantled the pilot jet , the pinholes seem clear, there was a little light brown deposit around the 2 pinholes which I cleaned off, maybe some of that had blocked the jet.
I noticed that there is an air vent just below the jet and if that had been partially blocked that would have the effect of weakening the flame back to how it was, but I can't see anything that could have been obstructing it.
I am not complaining that it now works, but am a little worried that the pilot may be burning too hard now, it makes a lot of noise, more than the main flame! It looks about the same size in the window as before, but comes out sideways rather than upward, as I said.
The only things I can think of that I could have done, are either :
I knocked the pilot while taking it off to inspect, and dislodged a blockage, or
while taking off and replacing the thermo at the gas valve end I also removed the unit between the main block and the thermo, where the wires from the safety cut-out go in on either side, and when replacing this without realising that it had a dual thread I had to turn it an extra half turn to get it back in the exact position it was before so the wires going in met up nice and easily, and I noticed on removing it again that this had caused slight compression of the little black washer that goes around the protruding bit of brass that fits inside the valve.
Sorry that I don't know the right name for these bits and pieces, and the system is actually working ok, apart from the noise of the pilot, it's not deafening, just definitely audible from anywhere in the vicinity of the boiler, whereas before it wasn't noticeable unlesss standing up close.
I believe from looking at manuals of later models, (Energysaver is the most similar that I can find onthe glow-worm site) that there is an adjustment for the pilot, near the pilot there are two slotted screw heads, one is grey/aluminium and nearest to the outlet of the pilot supply on the main block, the other is to the right of that and set about a centimeter deep and is brass. Is one of these to adjust the pilot and what is the other one for?
Can I get diagrams of this unit anywhere? I am an electronics test engineeer and would like to know more about the electrics.
With thanks
Hello
With thanks
