Hi all. I\\\'ve got a glow worm fuel saver 45F. Having problems with the gas valve. Basically when the boiler fires up the gas valve opens as it should and ignites. The only problem is the gas valve continuously tries to open and close at the speed of light.
From what i have tested the voltage is fluctuating which is causing this. It doesn\\\'t happen all the time it fires up but does several times a week.
A plumber looked at it and and changed the gas valve but now says its an electrical problem, which would make sense.
Would the problem be the circuit board in the boiler. I can\\\'t think what else it would be.
Thanks for any help.
Chad
Chad
