Hello, I have a Glow Worm Hideaway 50 BF permanent pilot fitted in a circuit which is open to atmosphere (header tank in cupboard).
The issue is that it fires up for only about 2 to 3 mins and then the burner turns off but the pilot remains alight. It will then sit dorment for about half an hour and then relight for another 2 mins and then burner goes out. The pilot always remains alight. There is water in the header tank and this issue happens whether I switch on the room stat on or the hot water stat on the cylinder ; makes no odds which.
Tonight I changed the thermostat for a new one and the issue remains ??
Any help very well received. Kind regards.......
