Hello.
I have a glow worm 24 ci combi boiler with a low pressure problem. The heating system occasionally needed toping up especially when system was cold.
Recently I took a radiator of to do some work in the kitchen. put it back on again and bled the system thoroughly. the system was constantly loosing pressure. saw that pressure relief valve had blown. also noted that the pressure went very high over 3 bar when system was hot then went right down to below 0.5 when cold. Know i need a new pressure relief valve and also want to check expansion vessel pressure which i learnt from another post.
Does anyone know the best way to do this on a 24 ci looks quite inaccesable. Manual just talks about removing boiler from wall for expansion vessel replacement. Do i have to do this just to check the pressure!?
Any info gratefully recieved M
