Glow worm Swift Flow 100e not firing?
11 Apr 2006
Nottinghamshire
Combi-Boiler not firing?
I think it was installed in 99 so not that old. When turning HW or CH on the boiler kicks into life as such but I think the actual heating part of it doesnt spark into life, there is no flame or whatever it is? Therefore NO HW or CH
Sorry Im not very technical but just any clue as to what this could be would be helpful at least then I can get someone in to solve it if possible?
Thanks in advance.
I have searched but not found anything specific - just things about a fan?
Thanks in advance.
start from the beginning with the hot tap on what does the boiler do
Thanks for the reply.
I switch the HW on I can hear the boiler coming on but it doesnt come on all the way in that the 'flame' doesnt start in the little glass window? This is the same when I turn the CH onto constant. It sounds as though it needs that final push for the flame to come on and actually start heating the water.
Check system pressure and if OK check continuity across pressure switch
Thanks for all your replies.
Had a CORGI guys in yesterday not sure what he did,but it seems to be firing now... ??
No parts replaced as such, I think the only thing he did was tighten the pipe(?) away from the fan.
Hoping it doesnt konk out again this week....
