I recently moved into a one bed flat which has quite an old (1993) Glow worm Swift flow 80 boiler. I noticed that the pressure gauge had gone down to 0.5 bar today when I came home. Since moving in in July the pressure has been at 0.7 bar and never dropped below this and I cant see any leaks anywhere. I filled it up to 0.7 bar on the filling loop.
When I went to turn the hot water tap on, water came out but the boiler didn't fire up.
If I leave the hot water tap running and tap the boiler on the side a click can be heard and the boiler fires. Sometimes it will stay lit (until the hot tap is turned off), or sometimes it will cycle on/off and click each time.
It has done this about three times since I moved in in July. Each time, I give the boiler a tap when it doesn't fire and it will work fine for ages as normal - although about twice now, after running the hot tap for a while, a strange gurgle noise is heard in the boiler, lots of water banging and the pressure will drop suddenly to 0 then return to normal again within a few seconds. After that the boiler usually refuses to fire up when the hot tap is turned on unless you wait for a few minutes. Pilot light remains on as normal.
However, at this moment no matter how much tapping I do the boiler wont stay alight. It clicks on when I tap it but will then click off again nearly staright away and not work!
I realise tapping a boiler is not the correct way to make it work and was going to get it serviced soon, but does anyone know what the problem could be?
Central heating is working fine.
Sorry for length of post, but does anyone have any ideas, or can recommend a freindly corgi plumber in the lightwater, camberley surrey area!
Thanks!
Thanks!
