Hi I am hoping someone can help me with a central heating problem....
Glow Worm Ultimate 40 FF Open vented fully pumped system
A radiator has been removed and another changed to a towel warmer.
The Programmer has been removed and refitted.
New pump fitted Grundfos 15/60 Super Selectric
New room stat fitted Drayton
After the radiator removal The first problem was that only the upstairs radiators and hot water were working. So i fitted a link pipe between the removed rad flow and return pipes. All rads were bled but still nothing downstairs. Soon after the boiler would not ignite. The fan would run only and it sounded like the pump was trying to pump water through the system with lots of gargling type noises from the pump pipework area. The boiler would fire very occasionally i think twice in total over a few days for 5 mins then cut out and back to fan running only.
The pump was changed and the boiler fired and heated up the only upstairs rads and hot water. So The system was bled using the drain cock and the downstairs rads began to heat. After about 20 mins the overheat cut out tripped and now the boiler has reverted to fan running and pump running with water swishing type noises from pump area. All rads have been bled.
A towel warmer has been fitted in place of rad and a new room stat was fitted. But still same problem.
I hope this makes sense !
Some advice would be much appreciated.
