Hi all,
I have a question with regards to this. Before anything else, I will be planning to get a new fuse tomorrow from Maplin and check if the old fuse has worn out. Does anyone have a problem with this before?
1) Boiler make / model (gas or oil)
Gas Glow worm Ultimate 40FF
2) What is / is not happening
Fuse (F2) blown. The fan will try to run but stop before reaching ignition stage.
3) Has ANYTHING else been done / changed recently
It just happen recently. What I can recall is that I did not switch off the boiler over night and when I came back the problem occurs.
4) When did it (problem) start
As described in (3).
5) When does it happen? eg, heating coming on or going off
When the heating is coming on.
6) Anything else you feel may be of relevance
I cannot think of anything that is relevent. Only that from the service manual, I know that only the first two neon lights are on but not the third and fourth. I did not have a multimeter with me (I know I should get one soon) so I cannot further diagnose the problem.
Any ideas into this are very very much appreciated. Cheers!
