Only had the boiler in for one week and I am now finding that when the boiler starts to run on central heating the radiator icon is on the lcd display along with the water temperature and the burner flame status on the right hand side, all is ok untill the water temperature reaches the temperature set point and goes over by two degrees then the tap icon flashes on the display and the heating stops running, it then goes into some kind of internal circulation for a few minutes then fires up on heating again untill two degrees over and the same thing happen's again.
I have had no problems at all with the hot water.
any information would be appreciated on the problem.
Switchmode.
Switchmode.
