Glow-worm upgrade??
15 Apr 2006
Lancashire
I have an old Glow-worm 45-60B balanced flue boiler. Can I can put a new programmer/timer on it?
If so, what should I be looking for? digital, electro-mech??
Cheers!
As long as you know what you're doing,
You need to replace like for like i.e. if you are switching live, you need to replace it with something switching live
A digital one with independent daily programmes isn't so expensive
I'd like to put a digital programmer on it... just not sure which ones will work on my boiler as it is quite old.
When the hot water is switched on, there's 24v AC supplied to my gas valve from the controller by 2 orange wires.
When I switch the heating on, 230v AC is supplied to my CH pump via 3-core cable.
Will a digital programmer work? The original mechanical controller only allows you to put the heating on when hot water is on.... again, does this mean anything?
Cheers
Cheers
The programmer controls the boiler/system, not the gas valves directly
Look on the back of the programmer and see if there is an interconnection diagram on the timer
whhat make / model is the timer and what model is the boiler ?
The boiler is a Glow-Worm 45-60B Balanced Flue. From what I can tell it was made round abouts 1983. The programmer is built into the boilers outer casing and the boiler is floor mounted. The control panel does have a wiring diagram on the back if that's what you mean about interconnection diagram.
System parameters will have a factor on what you can do.
Gravity h/w?
Fully pumped with no interlock on h/w or c/h?
Really need more info to give advise.
David
nick - I think you have to get a clue or get someone in.
It's fairly simple to do, but it involves you making an effort
I get the impression that you need someone who has an idea what's required
