gloworm 24cxi
17 Sep 2011
Leicester
hi
Can some one help me with gloworm 24cxi
it works fine on heating but on hot water after 2 minutes if hot water turn off and turned on the boiler goes to F1
the temp. on the boiler stay high, it does not dissipate heat and the pin on actuator does not go in to release the hot water to heating side to cool down boiler.
i have changed hot water heat exchanger, hot water thermister and diverter valve but the problem is still there.
only thing left to change is PCB, would it cure the problem?
please reply
thank you
