gloworm 30ci Whats the best setting for rad output?
23 Dec 2003
Just looking for info - want to ensure nice and warm and.... use the least gas possible!
Currently rads get nice and hot in no time and all is controlled by the room thermostat in hall and trvs on all rads except the one in hall
Boiler has a dial for setting the output for the radiators
Suppose i am not really sure why! Other that you get a higher output temp if you turn it up! But what for???
Instructions just say adjust for higher output - so no help!!!
I currently have it set at about 1/4 on (ie quite low)! and digital display shows about 55 degrees when the boiler is heating
Is this the best position?????? To get the best efficiency???
or is it best to have it set higher ie
is a low setting better so ticks along nicely or
is it better to have it higher and so blasts the heat out quicker!!!!!!
Many thanks
(probably another stupid question but hay someone may be able to guide me)
Cheers
Mat
m8tte said:
.... use the least gas possible! Mat
shame you haven't got the 30hxi or 30cxi. Otherwise we would have told you to put a little stat on the return pipe and adjust the dial so it hovers below 53 celsius.
You should use the LOWEST output temperature consistent with heating the house effectively - ie and in particular bringing the room temperature up from 'cold' to the level you want (whatever that is) in an acceptable time.
The lower the boiler temperature the less gas will be used. BUT avoid running a (non-condensing) boiler at such a low setting that condensation can occur in the heat exchanger - which will rot it! Keep the return temperature above 60 degrees for this reason.
