Gloworm 30Cxi leaking water
5 Jan 2009
Manchester
Help!!!!
My boiler is leaking from the condenser trap. I called the plumber and he said the trap was blocked up with black stuff and he cleaned this out it stopped leaking for a period of time but then started again so I pulled it out myself and again the black pipe and the condenser trap had blocked up so I cleaned it again. This time I flushed my system and put inhibitor in to stop the rust. but the bolier is still leaking I think the water is coming from the black plastic pipe that connects to the condenser trap, there is no more rust in the tubes or trap could the trap be faulty or Do I need to buy new pipes and if so can anyone tell me what i need to order also the boiler pressure is around 0.7 to 0.8 is this normal when I open the filling loop it leaks sometimes whe it was first installed the pressure was about 1.5 Many thanks for your help.
