gloworm compact...heating not working!
26 Feb 2007
Devon
a friend of mine has a gloworm compact & when you put it on to the heating setting it does not fire up! he does not have a room stat & it has a manual timer...the timer does not seem to turn when setting the time & when you set it to overide the timer function to have constant heating nothing happens! is the timer faulty?
you need to check for 230V at the switched live connection on the boiler wiring terminal.
Have you set the heating/hot water button to heating AND hot water (indicated by the appropriate LED) ?
was wondering if the timer could be bypassed so that i could check if it was faulty?
