Alright guys,
Was out there at a Gloworm Compact that was having lock out problems.
When i read the gas valve outlet pressure i getting 4 mB. The manual siad it should be around 15 so i went adjust it at the PCB. Found that the potentiometer was turned up full. Checked inlet pressure and this was fine at 24 mB.
Anyway i stripped the gas valave down and found that it was blocked solid with Copper Sulphide. the worst case i have ever seen!!! Screwed the gas valve back together and rechecked my outlet pressure. I know had 8.5 mb.
This value was the same for the DHW as well. Its potentiometer was turned up full also. Why would i not be getting the 15 mb reccommended.
I checked the coil resistance on teh outlet side and it was reading 1.67 K ohms. When i first checke dthe other side i was getting 3 K ohms. I rechecked and then wasnt getting a reading or (OL). Is this a gas valve on its way out or what else could it be??
Cheers
Grill
Cheers
Grill
