If my memory is correct the fuel saver f is fan flued & has electronic ignition every time the boiler fires. if your system is calling 4 heat & the boilers not responding you need help not advice.Not sure if theres an over heat re-set on theat boiler.If u hav the instuctions try lookin that up.
err glowworm there is an overheat cut-out button which if memory serves me right is on the box near the boiler stat (it will need a firm click to re-set it)
