gloworm / glow worm ultimate 40ff boiler problem
25 Oct 2008
Buckinghamshire
Hi. Can any one help me please. It's getting cold in here!
Last night my Gloworm Ultimate 40ff boiler has given up the ghost. It only now makes a faint humming noise when switched on which I guess is the electricity just activating the system. I only have neon lights 1 and 2 illuminated in the PCB. That leaves 3 and 4 which are not illuminated. These indicate failed airflow (light 3) and Ignition (light4).
The night before when it was working. It did sound a little noisier than usual. A bit like the fan was in need of lubrication and sort of whiney. Sorry I can't be a bit more technical but could anyone out there point me in the right direction of what to do to.....Over to you experts and thank you in anticipation
you need to remove the combustion chamer front , which is really a job for a corgi guy. Once removed , the seals need to be checked and once replaced it needs checking so as to ascertain a correct seal.
Hi again
I have given the fan a nudge and the boiler has sparked into life again. Thank you very very much. I must say though, the fan still sounds a bit noisy. Would you think it's on it's way out or is there any way of servicing or lubricating it etc. Once again Thanks for all your help
