Gloworm Majorca Three keeps going out
13 Dec 2005
Nottinghamshire
Hi, got a problem with my back boiler, it fires up then runs for about 30 seconds then goes out, including the pilot light. The pilot will ignite and appears to be stable until the boiler fires up. After relighting the pilot light a silly number of time yesterday the boiler eventually fired up and ran ok, however come this morning the same thing is happening.
Don't know if there is any relevance in this but I have just replaced the pump (bearings were totally shot), I had to drain the system to do this as the valves wouldn't close off properly. I was able to reduce the boiler temperature as the old pump had been clogged up and it was running great for 4 days.
Apologies for rambling on.
Air lock? Try air vent by HW cylinder. Or could be the thermocouple is dying.
Did you check which way the pump was flowing before you changed it as you may have put it back the wrong way round. but this would not cause pilot outage if it hasn't been seviced for a while you will need one as bbf uses air from room which is dusty. while it is being serviced have a t/c lead fitted (about 5 quid for part)
Cheers for your comments, the pump is the right way round. I just checked when I last had it serviced and I have someone coming round to do it on Thursday (it's been longer than I thought). Just been out and noticed that Transco have got the road dug up which may be relevant. I'll let you know what happens when the Corgi guy has been.
