gloworm micron boiler
10 Sep 2009
Norfolk
HI
i drained my central heating system today to replace a couple of rads and check my 3 port valve as i think it is stuck on heating only. replaced rads and checked valve. needs replacing but didnt do it today. i filled the system up and bled everywhere sucessfully bur when i went to start boiler nothing happened. then after turning it on and off a few times it started but i got flashing lights on reset and on burner and no heat. my boiler is a glowworm micron 40ff. anybody got any ideas? thanks.
No need to drain the system to do either of those jobs if the rads were like for like size wise.
they werent like for like size wise, but that aside can you help with my boiler problem
Do you have hot water? did you check the feed and expansion tank was full?
Oh right because it does sound like the fan is running. What is APS ?
