Gloworm Spacesaver 50 Kb/B?
30 Apr 2006
Durham
Anyone help me out, ive just been to price a job (o/v system boiler swap)and the boiler had 3 pipes going into it.
Can anyone identify what they are for me please 2 on left and one on right all 22mm-3/4 copper is one a cold feed/vent?
Which is which, cheers in advance. Oh if one is a combined feed and vent will it be ok to fit a air seperator above the boiler teeing the cold feed and vent in there, thanks in advance.
Forgot too mention its a fully pumped y-plan.
? Explain more why not use the combined feed and vent. Is this what the 3rd pipe is.
What would you recommend doing with this 3rd pipe (assuming its a combined feed/vent to fill system) tee it in just before the pump?
i was just thinking that generally i would consider that as not good practice.
i cant visualise the configuration of the spacesaver off the top of my head i'm afraid, but might it be flow, h/w return & separate c/h return
Forgive my ignorance but how would i configure that then. Join the HW and CH returns together? Ive never heard of that set up before ie HW and CH return.
its very common.
go back in time - gravity h/w & pumped c/h=2 flows & 2 returns.
if this were converted to y plan you may well get 1 f & 2 r.
check out old e types ,mexicos,wrs,wcf etc.
any way just work it out. check out the airing cupboard & attic.
where do the c/f & o/v go.
Timmy with only doing 3 jobs a day you should be able to spend time on this and work it out for yourself. :LOL:
It all depends what boiler you are fitting in place of the existing as some manufacturers recommend combined feed and open vents although the majority stipulate individual.
Why not fit a system boiler, it will take the hassle of running a pipe back up to the tank away and also work better
Im going to be fitting a o/v system boiler, i just couldnt get me head round the way it was piped up. I didnt get a good look at the f/e tank but a pipe came down from the loft and went under the floor, im assuming this was going to be this 3rd pipe into the boiler. There was also a 15mm pipe tee'd into the return (with a gate valve fitted bad practice?) in the cylinder cupboard.
I just thought some of the senior more experienced people on here would of known the set up of this boiler.
PS i dont do 3 jobs everyday sometimes more :eek:
So have you read the MI`s of the boiler you are fitting to see what it asks for.
First rule of pricing any job especially a change over is have a GOOD look otherwise you can seriously under price a job and end up looking incompotent in the customers eyes when you spend extra day on it
