Hi
I have a GlowWorm SwiftFlow 100 which no longer produces Hot Water. When I run the hot water tap I get a loud rattling clicking sound from the left hand side of the boiler which it has always done to a certain extent but this sound used to go away once the boiler fired up, almost as if the water flow was not enough to fire up the boiler. If I run the hot tap and bypass the flow switch the boiler fires and I get hot water but the rattling does not go away, which does point to the flow switch. Guidelines in the installation guide for measuring water flow suggest that there is adequate water pressure. I have tried tapping the flow switch to no avail.
So I suppose my questions are:
What is that rattling sound and is it normal?
I have seen scaling mentioned as a possible cause, how would I check or this and or cure it (There is a ceramic de-scaler in line)?
Is there anything else that could cause this problem?
Many Thanks in advance
