Ive got a Gloworm ultracom 30cxi, its been a right pain since it was installed 7 years ago, its had 2 heat exchangers since new.
Recently the shower has started running cold after about 1 minute, and the upstairs bath the same, the upstairs sink hot taps fluctuate warm/cold, never getting hot at all. Sometimes they stay warm for longer but always run cold after a while.
The kitchen hot tap runs hot and stays hot, this is the closest tap to the boiler.
What do you think could be the problem? Do I need a new heat exchanger again ? Since the last heat exchanger 2 years ago I had a limescale device fitted around the supply pipe, not sure how it works, it just clamps on. Hope this would prevent the heat exchanger clogging up again.
thanks
thanks
