Hi all,
Firstly glowworm have told me that my boiler is obsolete and can no longer send out an engineer as they don't have parts.
I have a problem with insufficient hot water reaching the shower. I have to lower the power on the shower to have it hot enough and have it on Max heat. I have fitted a brand new Mira shower so the shower isn't the problem.
I don't want to buy a new boiler as i will have to pay again to have it moved when I get an extension built in a few years time.
I've have had a few boiler guys round who said that the 2 bar of gas that were burning when heating hot water were very low and they thought it might be the PCB or the gas valve restricting it.
I changed the pcb for a new one the other day but no joy.
I've also had to replace the DHW diaphragm and switch as they were leaking and corroded
Would be grateful for any advice.
My gut felling tells me it's the heat exchanger clogged up and restricting the flow but a plumber disagreed as it doesn't make noise like a kettle or go hot and cold at the tap. When using the shower in winter it does sometimes go hot and cold though.
Any advice much appreciated
