Hi I have the glowworm 18hxi boiler and occasionally (more frequently recently) we get only lukewarm water when we run the hot taps etc. This seems to happen more frequently if we have the ch turned up (ch is always on at about 18c sometimes if it is cold we turn it up)
The boiler runs 12 rads, 8 of which are regular size and 4 are a smaller size, central heating appears fine as all rads heat up when required etc. The pressure in the system is within spec as well, and the boiler fires up when needed and doesnt show any errors.
Water pressure from the taps seems fine as well so I dont think there is any blockage
There are 2 honeywell motorised valves in the system, one appears to be the hot water side and has no resistance in the lever between auto and manual which I believe is correct as hot water is set to be constantly on, the other valve on the ch side does have resistance if the stat temp is set higher than the room temp.
To check the valves (they have the dimple on so can be swapped without bleeding the system) I have swapped them across the circuits (with wiring) and the same happens (resistance and no resistance same as above) so I think I can remove the valves from the fault. The pump a grundfoss (dont know model) appears to work as well on all 3 speed settings (currently on the lowest setting).
I tried to reset the boiler, and when I turn it on apparently it is supposed to show a pressure reading but it doesn't
Anyone any ideas on what the problem could be?
Cheers
James
Cheers
James
