- Joined
- 12 Sep 2015
- Messages
- 2
- Reaction score
- 1
- Country
My Glowworm 30ci boiler has failed and I'd appreciated any advice as no hot water or heating and my usual gas man is off on holiday.
Boiler fails to power up. Mains supply is fine and fuse on main pcb control board is fine. At switch ON there is a noise for a couple of seconds, perhaps a valve being driven and then nothing. The power ON LED doesn't light and the fault display never comes up, so no fault codes to work with.
It may be a coincidence but the boiler was serviced only a few days before problem. I've checked and reseated all connectors around the pcb but no joy. Is it possible during service something was not reconnected fully?
I suspect main pcb board but the part is too expensive to take a punt. Any suggestion on cause or method to multimeter test the main pcb would be much appreciated.
