- Joined
- 12 Jan 2006
- Messages
- 77
- Reaction score
- 1
- Country
Gloworm 30ci suffers loss of pressure. Works fine but when cold pressure drops under 0.5 bar. No leaks noticable except when filling up. Some scale on metal under PZV brass drain off. I suspect leak on Reduced Pressure Zone Valve. As I try to fill boiler there is leak on brass part of this valve. This apparently is common but this valve leaks when pressure reaches .6 or 0.7 bar so much it is not possible to fill boiler to 1.5 bar. I had to use screwdriver with cloth over the tip to close RPZdrain off hole to fill boiler.
Where can I get replacement part in NW London. I have searched net but could not fing part no.
Any advice on part no, for RPZ or web site. Can this be cleaned up or repaired?
PRV was changed did not fix problem. Boiler engineer has given up after 3 visits. No leaks on pipes or radiators.
