Would anybody know how the auto air vent should be set on a Glow worm 30cxi boiler. Ther is a cap and a small plastic screw, shopuld this screw be fully closed or open slightly to allow a vent?
All auto air vent caps should be left JUST loose by say 10° so that air is expelled but water is not able to leak too fast if they jammed.
Once the system has been commissioned and run for a few weeks some installers close them. This is not correct but does reduce callouts from them weeping. This is more common when the system water has not been properly cleaned.
