Due to continued problems I have had between glowworm and the installer, the outcome basically meant that we didnt have any hot water!
The previous engineer who visited showed me how to clean the Heat Exchanger as this seems to be the problem!
Having done this myself a third time, i sprung a leak from a plastic insert inside the boiler that hadn't been screwed all the way in by the installer.
I tightened it and the boiler has been running fine, except the water pressure has increased from .08/1.0bar to 1.5/2.2bar.
Is this increase in pressure safe or is it too high?
Should the plastic insert be screwed all the way into the metal thread? If so how do you stop the water spurting out?
As i say i have had to attend the boiler myself because whilst the installer/glowworm are arguing the toss, we had no hot water/heating!!
Thanks!
Thanks!
