Glowworm 30SXi with intermittent F13 faults
16 Dec 2008
Aberdeen
The F13 faults (main PCB connections, according to the manual) started a couple of months ago. All the connections seem OK and cleaning them with switch cleaner has made no difference. Switching off for a while usually clears the fault, occasionally it will clear by itself.
Any suggestions?
Where's the best place to get a replacement main PCB from?
hi, I am having exactly the same problem with my boiler that you had from your post back in 2008.
can you remember what the outcome was. was it the pcb board and did you end up getting a new one and did it then work.
thanks
lorraine
