I have recently moved to a new house about three weeks ago and was collared by one of the neighbours to fix his leaking boiler.The dhw flow sensor on the cold inlet had a split in the plastic moulding.I replaced the part and all was good until 8 o clock this morning knock on the door boilers leaking again.This time 3-way valve housing has a split in plastic.I suggested fitting a pressure reducing valve on the first visit due to the high pressure on the incoming main,but these boilers are rated to 10 bar aren't they?Is it common for the plastic to split?
.nb boiler 3 installed 3 years ago
