Glowworm Combi 38CXI. dripping water.
9 Feb 2015
Glowworm Combi 38CXI. The roof of the lower compartment, above and towards the left of the heat exchanger, shows water collecting and dripping whenever hot water is run. This does not appear to happen when the central heating runs or when hot and cold water are run simultaneously.
The upper side of the plate shows no water whatsoever. There is no evidence of anything spraying upward from the heat exchanger or any of the joints. The boiler is in an unheated conservatory and is against an old chimney (it now vents through flue to the side). It has been there 5 years and this problem has not been apparent before. Any ideas anybody?
