glowworm combi F4 fault
16 Nov 2006
Norwich
Hi, I have a glowworm 24 ci combi boiler and since having the heat exchanger cleaned of scale about a year ago it has been working fine. This morning however there was no hot water and the boiler displayed a red light with F4. I switched off the powere supply then put it back on again and the boiler worked fine. Could someone explain what the F4 means ( I have mislaid the manual ) and is this likely to be the start of more problems or simply a hiccup. Thanks in advance, Jocojohn
I looked at the instructions for the 30ci as the 24ci does not seem to be on the GW site.
However it does not list an F4 code. Either your boiler is different or its not a valid code.
Its not that unusual for boilers to give unlisted codes. When I once enquired about one the answer came back as "boiler fault, other".
If its working OK then I suggest you forget about it until it happens again.
Tony
hi you sure its not the cxi, because theres no f4 on the ci, but on the cxi f4 is pointing towards an ignition fault e.g no gas or electrodes.
F4 states it is the flame going out during demand.
Could be ignition problem, gas valve, low gas pressure, ignition leads, air inlet blocked, flue duct leaking, condensate trap blocked, as taken from the Glow Worm manual
Hello again, its now been about 2 days since the problem and its still working ok. The pressure when cold is normally about 1.4 bar which goes up to about 3 bar when the heatings been on for a while. If it was a component failure why would switching off then on again fix things? Thanks again for all your replies
