I have a Glowworm Compact 100e and am having an intermittent problem with the hot water. Every now and then (actually most of the time) the boiler locks out and the red LED comes on. This happens when I turn on a hot water tap while set to the Summer setting (i.e. CH is switched off).
It seems to makes all the right noises as if it's about to come on, apart from the final electrode click and gas firing.
If I turn the CH on (either manually or with the timer), the DHW will fire, 100% of the time.
The problem seems worse when the hot water hasn't been used for a while, around an hour or so. If the hot water has been used recently, then it doesn't seem so bad and will usually work.
This has been going on for a while but my Mrs is getting pretty fed up with it (and me) so any suggestions would be greatly appreciated.
