GLOWWORM COMPACT 100E PCB
28 Feb 2005
Hi there,
I have a 7 year old 100E combi boiler and think the PCB is faulty.
The problem is that when the CH is on the hot water solenoid on the PCB starts clicking quite loudly you can see the contacts fluttering making the noise, turning the hot tap on stops the fluttering for a time, another problem I now have is that when the CH is switched off at the thermostat the pump keeps going I have found that this is caused by the CH/pump solenoid staying engaged. I think the problem is the PCB but would like a second opinion.
If I do need a PCB I read on this forum that it needs to be set up, is this correct as I replaced my daughters Potterton PCB last year and away it went.
Please help :oops:
Yes on both counts, I've had the same a couple of times with a relay clicking away on the board and needs a new pcb. You need a manometer to set the hw and ch gas pressures on the board which you do with the little black key.
Thanks for the speedy reply you are a credit to the forum, I was expecting the PCB to be pre-set to the correct parameters so why does it need adjusting ?
Could you tell me what will happen if I just change the board without adjustment and also what the settings should be if I can get hold of a manometer before Xmas. :eek:
Some pcbs are just a simple swap, particularly the older more basic boilers, however many require setting up. Other safety checks must also be carried out to ensure the boiler is functioning correctly.
Sometimes there can be several adjustments required and if not done correcty the boiler could:
Fail to ignite
or ignite with a bang
or overheat on hot water
or overheat on heating
and several other scenarios
Either way it involves the gas valve and from your questions you have insufficent knowledge to be competent (ie legal) to set it up. The compact series in particular are very sensitive (due to a cheapo gas valve type) to the board adjustments and it is common to find them burning too much gas...ie not safe.
Call someone in.
Thanks again, I don't do gas so I was going to get someone in but I wanted it working over Xmas as I am currently switching the boiler off at night and when I go out. I can't get a board locally so am relying on the post to get it. Your reply has convinced me to wait until after Xmas before installation.
Thanks again
