Hi guys have a problem with my hot water, comes on for ten seconds then burner goes out. Ten seconds later it comes on again. There are similar problems on here but not exactly.
With info on here I have done some invest. The DHW micro switch and diaphragm seem to be working fine but the pressure differential micro switch pin seems solid.
My question is could it be a knackered diaphragm on the diverter valve be causing my symptoms?
My heating is working fine.
Thanks in advance.
Shinner
Thanks in advance.
Shinner
