Hi - Can you help? I have a Glowworm Micron FF60 Boiler and it has gone into "Non Volatile Lockout" - Reset light is solid green, boiler and everything restarts after turning off the temp dial and back on again. The fans work, it produces heated water, the pump is spinning (albeit its pretty quiet). After a couple of minutes the boiler switches off again. Its a conventional boiler not a combi. Just before it switches off you can hear the boiler sounds like a kettle warming up, as if the water is being heated but not going anywhere - not especially noisily but I don't recall hearing those noises before (its in an outside cupboard so I'm not completely familiar with its noises, but this is predictable its getting too hot). For the brief few minutes it is on, the rads start to get warm (I have not checked upstairs rads only downstairs thinking about it).
So, in essence, everything works when its working - what could cause lack of flow and should boiler make kettle type noises - I assume the temp thermostat is tripping out the system, but is it because it is too hot or because its faulty? The boiler will turn back on immediately if you reset immediately
