Hi all,
My elderly parents boiler is playing up. Had a heating Engineer out as it kept doing silly things, various error codes. He replaced the PCB, thermistor and phial. Since then it has been going into reset which I understand means it has overheated. Called the plumber back, he promised to visit but hasn't showed up and now won't answer my calls.
It is a rather old system and the 60ff isn't the first boiler to be on the system. It's open vented and the tank looked full of sludge so I thought I would have a go. I drained down as much as the system as.i could, not easy as very few drain cocks. I put in some Fernox F3. Hoping this will show some improvement. So my question is, does anyone think this will solve the problem and also as I can't drain it easily is it ok to leave the F3 in the system?
