I have just moved house and now have a Glowworm Spacesaver mkII boiler with storage cyclinder (installed in 1986 apparently). The problem I have is that the boiler only fires when there is a demand to top up the hot water cylinder. i.e. when hot water has been used the boiler heats up hot water and the radiators fine, no problems.
But when the hot water cylinder no longer demands heating, the boiler stops firing to the radiators too (even though the temperature is well below the level sewt on the thermostat).
I have changed the thermostat and this doesn't sort the problem. The system seems to work fine when the water cylinder is being heated, but not when it isn't being heated.
Any ideas on the likely cause? Thanks. in advance.
