I have a Glowworm Swift Flow 80 Fanned Flue Combi Boiler. Recently I have had the Expansion Vessel changed and as water was still coming out of the overflow a new pressure valve and pressure gauge were fitted which cured the overflow problem. However the pressure reading of 1.5 drops to zero in a matter of 2 or 3 hours so that it constantly needs to be topped up.
On the upper floor I cannot see any leaks which I think would quickly become apparent in the ceiling. On the ground floor there are also no visible leaks. The radiators appear to be okay with no air venting required. As long as I have brought the pressure up to 1.5 all radiators get hot and I can get hot water in the bathroom. However the problem persists, with pressure dropping to zero in a matter of a few hours after bring the reading back to 1.5.
