I was having a shower and the hot water turned cold and never warmed up again. The pilot light is lit but the burners do not light when I turn on the hot water. There are three lights: MAINS, RUNNING, LOW PRESSURE WARNING. The only one that is lit at all is the MAINS light but it is very very dim (only possible to see with the kitchen lights off). When I turn the water on, nothing happens. When I turn the hot water on very fast the MAINS light goes off. After about a second, it flashes on momentarily and goes off. It repeats this once per second (or a bit slower). It stops doing this when I turn the hot water tap off and the MAINS light is then lit but dim (again).
We have turned the mains supply to the boiler off for about 1 minute and then turned it back on again. No change.
Has anyone seen this before?
Thank you
Thank you
