Hi there,
I am perplexed. If anyone has any ideas on the following, I'd really appreciate it:
I have a Glowworm Ultracom 18sxi high-efficiency condenser boiler located in my garage, and for 2 years it has worked fine. However, twice now (before Christmas and this morning!) it has failed to fire up in the morning. Both times, it has been a very cold night (frosty/ice outside) and when I have looked in my airing cupboard to see what the system pressure is, it has read virtually zero. So, I have re-pressurised and taken the gauge to approx one bar......and the boiler then fires up and the house gets nice and toasty.
BUT.....when I checked the gauge an hour later, it was reading approx 3 bar and when I looked outside the pressure relief pipe was spluttering out some water! Normally, when cold the gauge reads approx one bar and when hot approx 2 bar.
So.....can anyone suggest why the boiler failed to start on an icy morning, yet adding water (increasing pressure) caused it to fire up, yet the pressure then rocketed?
My only thought is: the condensor drain pipe might have frozen, causing boiler (as per design) to fail, but don't see why gauge in house would read zero, nor why adding "fresh" water would solve this (but it does kinda explain why the pressure went up to 3 bar, if really it was already at one bar and then I increased it by one bar.....I'm clutching at straws here!!)
Any ideas?! Thanks for your time,
Matt
Matt
