It will be a roll 4m x 5m , , the area its going on , is larger (6 x 5) but i dont want joins so will have decorative trestles etc along the sides , but the front , will go up to the edge of the patio which is a step , so will need to secure that edge down really to avoid a trip hazard....[/wiki]
I'd be tempted to use a stair nosing across the edge of the step the material will be laid to rather than a glue. Nip it down onto the upward facing edge of the step with some small screws into rawl plugs will secure it nicely.
However, if you want to glue, any kind of long life exterior no nails type stuff in a cartridge will do, the backing of artificial grass the weft is bonded to isn't particularly fussy.
