I have 2 questions if someone would be kind enough to answer
1) Where is best to buy the glue for solid oak floor being fitted floating. I assume its just PVA most places sell tubs but i will need a bottle with nozzel.
2) I have one room that has wood floorboard construction and the other adjoining room via a 2 meter opening is concrete which i'm flooring straight through from one to the other. If i were to secret nail the new floor in the floorbaorded room can you then use self adhesive underlay in the concrete room both will be covered with plywood. Or will it all need to be fitted with the same method throughout as i wont be able to secret nail to concrete.
