Following my earlier post about drilling into my front door I have had no replies suggetsing that it is possible so I have come to the conclusion that I will have to glue the door knocker on. can somebody recommend an adhesive that will do the job?
Obviously it needs to be water resistant as it is for exterior use, it needs to resist the impact of the knocker, it needs to be able to bond upvc and Brass and it needs to either dry clear or white so that it gives a good finish on the front door.
Can somebody recommend an adhesive that will do the job?
Andrew299
Andrew299
