glued or click engineered oak floor: which is quieter?
30 Jul 2013
London
I've had advice from 2 carpenters, both experienced. One says I should lay click system engineered oak flooring of at least 18mm with acoustic underlay in my flat, on top of screwed down floor quality chipboard. He says glued is noisier as it tends to move more after a short while.
The other says glued is better, 15mm is ok and 8mm acoustic underlay sufficient.
I currently have a tatty old carpet, so have no idea who's right. It's a flat, so there are downstairs neighbours to consider, but can't/won't go with more carpet due to both allergies and to the neighbours' collective refusal to do anything serious and ongoing about a moth infestation. Am not going to buy the moths a new £££ dinner!
Floor is for lounge, kitchen area and passage, about 50m2.
Any tips on where to buy the floor and also the acoustic underlay much appreciated. I've been reading until I'm square eyed on the subject and am stuck. Americans seem to use cork underlay for soundproofing, but I think in the UK it's acoustic underlay?
thank you
A floated click or glued floor will be as noisy as each other.
A solid floor fixed to the subfloor will be quieter then a floated floor.
Check the deeds to your property,many flats will have it stipulated that wood flooring etc cannot be fitted due to transfer of noise even on a solid, fixed floor.
Most flooring suppliers can supply a fibrebpard underlay within specs of the floor you are buying (usually no more than 4-6mm thick)
