Hi, i've just had a new carpet laid and the fitter has cut it to exactly the room size and glued it in place. The edges have not been knocked down between the skirting and the grippers. He says he had to do this because there was a bead in place between the skirting and floorboards. He says that the carpet will not fray at the edges and will be fine. As the edges are exposed I am concerned that they will fray and that the edge is not tidy enough. The old carpet was attached to grippers. There is a bead in place. Is glueing carpet in place good practise? If I take the bead out, will it be possible to have this carpet fitted to the grippers or is it too small now its been cut to the room size?
