I want to create some bogus half-timbering on the outside of a 60s ground-floor extension. Mock Tudor. Wood, then render between.
The wall is hard concrete block with sound cement render, masonry painted.
I plan to use cedar because it's stable - not likely to warp and won't rot. About 5x0.75".
To avoid a lot of fixings and plugs, I'd like to glue it in place. I've never used anything like No More Nails, but I believe such adhesives can be used to attach wood to the wall. I presume the wood should be primed on the back and the wall Unibonded.
What would you recommend?
