Gluing abs plastic to plywood, which glue?
3 Sep 2011
Hampshire
Hi there,
I'm in need of some advice for gluing a large area of ABS plastic 0.8mm to some exterior plywood. The seal needs to be water tight as it's for a rabbit hutch.
It's a 1.5m² area so quite large, I was thinking of using Polyurethane glue something like Gorilla? Or perhaps a Powdered Resin glue?
Thanks in advance.
Dale.
One of the new fix and seal it'll do anything type products would be better than polyurethane. If you tried to do it in contact adhesive which would be best it'd be expensive.
CT1 Tec7 007 etc will all do and be unaffected by water, you can then use the same stuff to seal around the edges.
